07-12-2019 12:30 AM
Hello
I have written the following moving median filter code -
module median_filter_main(clk,A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,window,med);
input [7:0]A0,A1,A2,A3,A4,A5,A6,A7,A8,A9;
input [3:0]window;
input clk;
reg [7:0]max,min;
output reg[7:0]med;
integer i,j,k;
reg [7:0]temp;
reg [7:0]arr[0:9];
reg [7:0]array[0:9];
reg [7:0]dat0,dat1,dat2,dat3,dat4,dat5,dat6,dat7,dat8,dat9;
always @(posedge clk)
begin
dat0 <= A0;
dat1 <= A1;
dat2 <= A2;
dat3 <= A3;
dat4 <= A4;
dat5 <= A5;
dat6 <= A6;
dat7 <= A7;
dat8 <= A8;
dat9 <= A9;
end
always@*
begin
array[0] = dat0;
array[1] = dat1;
array[2] = dat2;
array[3] = dat3;
array[4] = dat4;
array[5] = dat5;
array[6] = dat6;
array[7] = dat7;
array[8] = dat8;
array[9] = dat9;
for (i = 10; i > 0; i = i - 1) begin
for (j = 0 ; j < i; j = j + 1) begin
if (array[j] > array[j + 1])
begin
temp = array[j];
array[j] = array[j + 1];
array[j + 1] = temp;
end
end
end
end
begin
arr[0] <= array[0];
arr[1] <= array[1];
arr[2] <= array[2];
arr[3] <= array[3];
arr[4] <= array[4];
arr[5] <= array[5];
arr[6] <= array[6];
arr[7] <= array[7];
arr[8] <= array[8];
arr[9] <= array[9];
end
always@*
begin
for(k=0;k<10;k=k+1)
begin
if((k-window)>k)
assign max=k;
if((k+window)<50)
assign min=(k+window)-1;
assign arr[k]=arr[(max+min)/2];
assign med=arr[k];
end
end
endmodule
I am getting an error as - bit-select or part-select is not allowed in a assign statement for non-net arr for this line in the code - assign arr[k]=arr[(max+min)/2];
and now If i declare array arr as wire then i am getting an error as - procedural assignment to a non-register arr is not permitted, left-hand side should be reg/integer/time/genvar
for these lines -
arr[0] <= array[0];
arr[1] <= array[1];
arr[2] <= array[2];
arr[3] <= array[3];
arr[4] <= array[4];
arr[5] <= array[5];
arr[6] <= array[6];
arr[7] <= array[7];
arr[8] <= array[8];
arr[9] <= array[9];
So how to declare array arr in the code as a reg or wire and how to avoid the errors coming because these declarations.
Please help with this. Waiting for your reply at the earliest.
Thank you
07-12-2019 02:59 AM - edited 07-12-2019 03:00 AM
Hi @kp1998_ ,
Assign inside an always block is the procedural assignment. It is not synthesizable and should not be used.
Continous assignment, or assign outside the always block is there for connecting nets and used
all over the places. LHS of such an assignment must be a net type. it cannot be a reg.
On the other hand all LHS in always blocks must be of 'reg' type.
Raj
Hi @kp1998_ ,
Raj
07-12-2019 03:34 AM
07-12-2019 04:58 AM
07-12-2019 06:09 AM
This design does not work.
Even if it would work (and it won't), if you cannot tell if your design works or not, then it does not really work.
Why is this so? Because everything needs to be maintained at some time, and asking someone external to verify your code every time you make a change isn't really a sustainable business model.
Personally, this is not how I would approach this problem. Sorting 10 8-bit numbers in a single clock cycle is going to force you into a slower clock rate, since very few other operations you might do will require this. How exactly I would approach the problem, though, would be system context dependent. Questions I'd ask first include things like 1) how fast is your data arriving? 2) How often does the median filter need to produce an answer? 3) Are approximate answers "good enough", and so on.
Dan
07-12-2019 06:43 AM
Hello
I am currently working with 10 inputs and will later increase the number of inputs to 500.
So is it better to consider the inputs together.
The median filter should produce a result everytime the window moves towards the right.
And yah approximate result is fine.
Could u suggest some way to correct the code as this not correct.
Would be great help
Thank you
07-12-2019 08:46 AM
07-13-2019 05:30 AM
To operate on faster data, at a high clock rate ...
This works great on high speed signals where you can afford whatever time it takes for the operator to converge.
Dan
