Visitor mrgaddis
Need help with ProjectMgmt:387 error
My design is getting through synthesis and is failing Translate in ISE 14.2.  The error that is being indicated is:
ERROR:ProejctMgmt:387 – TOE: ITclInterp::ExecuteCmd gave Tcl result ‘invalid command name “0”’
I have been reading the forums and the advice has ranged from restarting ISE to setting certain process options.  I did read that this error could be due to a DRC check error.  Is there a way that I can check that output?  Is there any advice you can give to help me troubleshoot the source of this error?
Marc
Re: Need help with ProjectMgmt:387 error
Refer below links:
http://forums.xilinx.com/t5/Implementation/ERROR-ProjectMgmt-387-in-ISE14-7/m-p/374193/highlight/true#M7299
http://forums.xilinx.com/t5/Design-Entry/ERROR-ProjectMgmt-387-TOE-ITclInterp-ExecuteCmd-gave-Tcl-result/m-p/219677/highlight/true#M3137
Anusheel
Helpful answer -> Give Kudos
Can you share the .bld file here to see whether there are any helpful messages is being printed in log file?
Vinay
Visitor mrgaddis
Thanks Anusheel,
unfortunately, I have already reviewed those posts and they don't provide the information that I need.
Visitor mrgaddis
I don't think that I can send .bld file, but it is helpful to know where to look. Is there anything specific I can search for?
Visitor mrgaddis
Here is the entire message when I try to run Translate:
ERROR:ProjectMgmt:387 - TOE: ITclInterp::ExecuteCmd gave Tcl result 'invalid command name "0"'.
Tcl_ErrnoId: unknown error
Tcl_ErrnoMsg: No error
_cmd: ::xilinx::Dpm::dpm_chTransformExecuteForNgdbuild dpm_ngdbuildRun $piThisInterface
errorInfo: invalid command name "0"
    while executing
"$_iNetlistNode getModuleName sModuleName"
    (procedure "dpm_xpsSearchNetlist" line 4)
    invoked from within
"dpm_xpsSearchNetlist $_iNetlist "" $_edkModuleName _hierPath"
    (procedure "dpm_xpsGetEdkInstName" line 28)
    invoked from within
"dpm_xpsGetEdkInstName $iTranInst $sModuleName "
    (procedure "dpm_xpsHandleXpsBmmFile" line 38)
    invoked from within
"dpm_xpsHandleXpsBmmFile $iTranInst _edkBmmArg"
    (procedure "dpm_ConstructCommandLineNgdbuild" line 168)
    invoked from within
"dpm_ConstructCommandLineNgdbuild $iTranInst cmd sModuleName"
    (procedure "::xilinx::Dpm::dpm_chTransformExecuteForNgdbuild" line 29)
    invoked from within
"::xilinx::Dpm::dpm_chTransformExecuteForNgdbuild dpm_ngdbuildRun $piThisInterface"
Hello @mrgaddis
Check this similar thread: http://forums.xilinx.com/t5/Design-Entry/Error-on-ISE-manual-compile-order-with-MicroBlaze/td-p/163974
Vinay
Visitor mrgaddis
Thank you Vinay,  that solved the problem.
Best,
Marc
Hi Marc,
Please close this thread by marking the answer.
Deepika.
Deepika.
