mharris-t
No IP matching VLNV 'NetFPGA:NetFPGA:input_arbiter:*' is accessible for the current part 'xc7vx690tffg1761-3'
My system info:
LSB Version: core-11.1.0ubuntu2-noarch:security-11.1.0ubuntu2-noarch
Distributor ID: Ubuntu
Description: Ubuntu 20.04 LTS
Release: 20.04
Codename: focal
Python env ver: 2.7
Board: NetFPGA Sume Board
Project: P4 NetFPGA Project
Xilinx Version: 2020.2
SDNet Version: 2018.2
I am using the NetFPGA Sume development board to understand its technicalities and work flow with P4. I am using this tutorial to program the switch calculator in the board. I am stuck in step 9, where I need to run the simulation with the GUI. I get the following error when I run the command:
 ./tools/scripts/nf_test.py sim --major switch --minor default --gui
The error is as follows:
ERROR: [Coretcl 2-1132] No IP matching VLNV 'NetFPGA:NetFPGA:input_arbiter:*' is accessible for the current part 'xc7vx690tffg1761-3'.
Before this error appeared, I copied the input arbiter folder from the P4 repo to /tools/Xilinx/Vivado/2020.2/data/ip/xilinx/ and made the changes to vv_index.xml file as follows:
	<IP>
		<VLNV value="NetFPGA:NetFPGA:input_arbiter:*">
		</VLNV>
		<DisplayName value="NetFPGA Input Arbiter">
		</DisplayName>
		<HideInGui value="false">
		</HideInGui>
		<!-- <CoreRevision value="4">
		</CoreRevision> -->
		<Description value="NetFPGA Input Arbiter">
		</Description>
		<ComponentPath value="xilinx/input_arbiter_drr_v1_0_0/component.xml">
		</ComponentPath>
		<Taxonomies>
			<Taxonomy value="na">
			</Taxonomy>
		</Taxonomies>
		<!-- <AutoFamilySupport value="Level_2">
		</AutoFamilySupport> -->
		<SubcoreVLNVs>
			<SubcoreVLNV value="xilinx.com:ip:axi_lite_ipif:3.0">
			</SubcoreVLNV>
		</SubcoreVLNVs>
		<VendorURL value="http://www.xilinx.com">
		</VendorURL>
	</IP>
Any help in resolving this matter will be beneficial for me.
