yu_chenthu08
No drivers are generated when Creating a new AXI peripheral
Hi all,
      I'm tying the latest Vivado/Vitis 2020.1 and have found a problem when "Creating a new AXI peripheral". No driver files for the AXI interfaces were generated automatically after I created the IP. In the former 2019 version a simple template driver were generated for the basic read/write on the AXI register/memory.
      Two related phenomena are as below:
      1) The tcl command called during the "Creating a new AXI peripheral" is "generate_peripheral -example_design ... -bfm_example_design..." while in the former version "-driver" was used.
      2) The drvier files we obtained from the former version Vivado seem to cause a make failure in the latest Vitis IDE. It seems to be related with the makefile but I don‘t know why.
      Could you please help solve the problem? Thanks!
syedz
@yu_chenthu08
HarisA
I am currently facing the same problem. Did you manage to find any solution?
HarisA
Hi again,
I've managed to find a solution. The problem seemed to lie within the Makefile. I used one of the preexisting driver Makefiles within Vitis when creating a platform project as template, simply replacing the names within the used file with the name of my new AXI peripheral. I was then able to successfully assign the driver to my peripheral and use the driver files within an application.
syedz
@yu_chenthu08
