Non-Module file on vivado 2019.1 with PYNQ
Hi all,
Im trying to create a wrapper to gnerate a bit stream on vivado with my PYNQ-Z1 board and a PMOD AD1 from digilent. However, I ran into a problem of non-module file that I couldnt figure out how to fix it. Could you direct me how to fix it please? Thank you.
If you open the file in the Vivado editor, is the status in the upper right corner green or red?  For some syntax errors, Vivado won't let you even try to synthsize it.
It is green.
I can't synthesize it if the wrapper is in the non-module file. I couldn't figure out what the error
