Package IP for distribution without including original VHDL code
I was wondering whether there is a way to package an IP for use by someone else, without including the original VHDL code.  I can pre-target the device that will be used, so the customer will not need to re-package or re-target the code.
Is there any possibility of doing this?  As far as I am aware, removing the code manually would result in "black box" instance issues.
Any help would be greatly appreciated!
Re: Package IP for distribution without including original VHDL code
Ok, I seem to have figured it out.
After synthesizing the project to be packaged, save the Synthesized design as an EDF file, which you can import into a "temporary project" that will be packaged (instead of importing your HDL sources).
If someone knows of a faster (more streamlined) workflow for this, I'd really appreciate it if you let me know.  It's surprising that it's not simply a checkbox option in the IP packager (I can't imagine that I'm the only one with this requirement).
