Participant baf2099
Package a block diagram with RTL module reference?
Is it possible to package a block diagram with RTL module references in it? I ask because I don't see anything to the contrary in the Xilinx documentation, however I tried to do exactly this and received the following error...
[IP_Flow 19-4639] Packaging block design '<>' with a module reference '<>' is not supported in this release.
Participant baf2099
Re: Package a block diagram with RTL module reference?
My question has been sufficiently answered here...
https://forums.xilinx.com/t5/Design-Tools-Others/Problem-with-simple-IP-Creation-Module-Reference-not-supported/m-p/755940
...Unfortunately, the answer was it is NOT currently possible in Vivado 2016.4. Would like to see this capability added though.
Participant baf2099
Participant dave74321
It still does not seem possible (Vivado 2017.4.1)
Is sorting this on the Xilinx to-do list?!
Yes, this should be available in Vivado 2018.1.  i just ran a test case and my BD packaged fine with an RTL module in a recent internal build.
Visitor dwjbosman
I am trying to package a block design which includes an RTL module in vivado 2018.2. Packaging finishes without errors.
Then I create a block design in which I use the packaged IP. Synthesis completes. But during implementation the following error occurs:
"[DRC INBB-3] Black Box Instances: Cell 'design_1_i/bram_mux_0/U0/design_1_i/mux_0' of type 'design_1_bram_mux_0_0_design_1_mux_0_0' has undefined contents and is considered a black box. The contents of this cell must be defined for opt_design to complete successfully."
IP packager file groups:
During synthesis there is already a warning:
So why isn't mux.vhd found during design synthesi/implementation?
