Packaging constraint files
I have a custom IP which contains a constraint file custom_ip_clocks.xdc, in which I have a single constraint.
I used the Xilinx FIFOs to figure the right way to do it, they're actually identical:
set axi_clock [get_clocks -of_objects [get_ports s_axi_aclk]]
set_max_delay -from [get_cells signal_detected_reg[*]] \
-to [get_cells state_reg_reg[*]] \
-datapath_only [get_property -min PERIOD [get_clocks $axi_clock]
Once I use this IP in a design, I can see in the synthesis & implementation log files that this constraint is being used.
If I ever use this IP twice in the same design, I can see that the constraint is only applied to one of the two objects, leading to a faulty timing analysis.
Which information am I missing so the embedded constraint file is applied to each instantiation of this IP in a global design? like the Xilinx FIFO for instance? I would like to keep the "embedded constraint files" unaware of what is happening at the upper level, just like the FIFO
thank you
edit:
I went through the related paragraph in ug1119-vivado-creating-packaging-ip-tutorial.pdf in which Xilinx specifies all of their *_clocks.xdc files are packaged with the "LATE" processing order. I modified the processing order of this very constraint file to that value, but it did not change anything. Processing order would fix a problem like --get_clocks returns null, my problem is the constraint is applied to custom_ip_0 but not to custom_ip_1.
I also forgot to mention the problem shows up even when custom_ip_0 and custom_ip_1 share identical configurations (I'm talking about GUI based customizations)
G.W.,
NIST - Time Frequency metrology
Re: Packaging constraint files
Hi @guillaumebres
Which version of Vivado are you using?
This issue was reported in older versions of vivado and this has been fixed in new releases. Please try using Vivado 2016.2 and let me know if it helps.
Deepika.
Hi @guillaumebres
Deepika.
@vemulad,
thank you for your time, I was running 2014.1, I am switching to 2015.4 today.
I will let you know if that solved the problem
G.W.,
Hi @guillaumebres
Any progress on this?
Deepika.
@vemulad,
Hi, I upgraded to v2015.4 last week,
it took me a couple of days to upgrade all my IPs but the problem was solved right away, thank you
G.W.,
