Parameterize Ip catalog for IP resuse?
Hello All,
I am creating a 4x4 cluster of block memory that will be used for flash memory essentialy.
How would I go about parameterizing these blocks with the IP catalog? Is there a way I can override the .C_INIT_FIlE parameter so I can reuse IP blocks? Can the IP block output be all verilog or is it set to VHDL? IS there a way I can override this?
It would make a lot more sense to be able to parameterize my blocks and just override the .C_INIT_FILE so I can resuse each individual coregen memory block.
Best,
Jon
no its not supported yet. this feature is in roadmap and available in future releases
Thanks and Regards
Balkrishan
