Parameters list for custom IP - GUI
is there anyway to tell the user of our custom IPs which values are available for a given parameter? (customize block interface).
thank you
gw.
Embedded Systems, DSP, cyber
You can use drop down for the parameter (list of values) if the number of values are less. Else use "range of integers", the valid range will be visible in customization GUI.
Refer to page-41 to 44 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_4/ug1118-vivado-creating-packaging-custom-ip.pdf
Deepika.
Deepika.
Deepika.
Deepika.
thank you very much this is great,
so we just have to check 'restricted values' and set the list of values.
gw.
