Observer chika
Partition Definition on Custom IP inside block diagram
Hi All,
im getting really confused how to add custom ip inside a block diagram and then make it reconfiguratble? if i right click on a custom IP in the sources window and click "Create partition Definition" it brings up the error message below. I cannot wrap it in a HDL wrapper, (or how do i wrap it when it is in a block design?).. i know there is a mention of not being able to make IP reconfigurable.. but i dont understand how to make custom IP reconfigurable?
回复: Partition Definition on Custom IP inside block diagram
This is OK:
             Top
              +...your module(RM)
              +...block design
                         +...other IP
This is NOT OK:
            Top
             +...block design
                        +...your module(RM)
                        +...other IP
Hi @chika ,
In fact, defining reconfigurable partitions has limitaions. Please refer to https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug909-vivado-partial-reconfiguration.pdfpage 52.
Observer chika
Thanks @yangc . i have seen this page. So i guess the question is then: how do i bolt my custom IP onto a wrapper that contains a block diagram for the rest of my design.. and then make "my IP" configurable ?
Please refer to https://forums.xilinx.com/t5/Vivado/Module-with-Block-Designs-type-of-sources-in-its-hierarchy/m-p/959895.
Observer chika
k so let me get this straight.. "Block Diagrams cannot be set as RMs." so.. if i want to plug my IP.. even if i used HDL source only .. and connected it inot an AXI interconnect.. that is part of a higher block diagram.. i cannot do this??
Observer chika
sorry type ' Modules within  Block Diagrams cannot be set as RMs" ..
What's meaning of higher block diagram? You can't set any modules as RM in block design. But if your module outside connect with block design , it(your module) can be set as RM.
Observer chika
Ok so:
This is OK:
--> Module --> block degisn --> other IP
This is NOT OK:
--> block design --> other IP + module
This is OK:
             Top
              +...your module(RM)
              +...block design
                         +...other IP
This is NOT OK:
            Top
             +...block design
                        +...your module(RM)
                        +...other IP
Observer chika
Ok thankyou.
