rmogster
Problem with generated tcl scripts
I used the Vivado tool to generate the tcl scripts for Synthesis and Implementation + Generate bitstream.  I used the "scripts only" option to get the files.  I ran the synthesis tcl script in a windows command window.  It finished with no errors.  The script took about as long as a GUI run.  Then I ran the  Implementation tcl script.  It failed and generated the following line.
ERROR: [Project 1-9] Cannot open structural netlist because no structural source files were specified. Edif, ngc ngo and verilog structural netlists are supported.
I ran Synthesis from the GUI, then re-ran the Implementation tcl script from the command window.  This time it worked.
What do I need to do so I can use just the tcl scripts, in non-project mode, to compile the project and generate the bitstream file?
Thank you.
thakurr
Hi @rmogster
Once you run the project in the GUI mode till bitstream. There will be  tcl scripts generated in the .runs/synth_1 and .runs/impl_1. You can use these scripts for non-project mode. You can follow the below steps.
1) Open Vivado tcl shell.
2) Cd to the location where the scripts are present.
3) source xx.tcl
Rohit
Rohit
thakurr
Hi @rmogster
3) source xx.tcl
Rohit
Rohit
rmogster
That works well.
johnbdunn
BTW I stupidly clicked the 'do not ask me again' box on the green 'play' button where it normally gives you a chance to run the systhesis or just generate the tcl scripts for it. Now I can't gen scripts, and I might want to do that soon
I don't suppose anybody knows how to get the script generation option back up again once you've done that?
surajc
@johnbdunn
Go to settings and check uncheck as per your preference
--Suraj
johnbdunn
Thanks Suraj, I knew it had to be in there some where
