msauerpb
Problems with migration from Vivado 2017.4 to 2020.1 with microblaze design
in our project (Artix-7 200) exits two microblaze soft ip. If I open then design in Vivado 2020.1 I will get the following error message:
 [BD 41-1712] The specified IP 'xilinx.com:ip:microblaze:10.0' cannot be found in the catalog. Check if the IP has been removed or if a newer version is available.
 [BD 41-595] Failed to add ip repository block <microblaze_0>
 [BD 41-1157] Failed to parse Design <TopLevel> from BD file <Q:/Vivado_V2_MultiCore_2020.1_orig/TopLevelProject.srcs/sources_1/bd/TopLevel/TopLevel.bd>
 [BD 41-425] Failed to read Diagram <TopLevel> from BD file <Q:/Vivado_V2_MultiCore_2020.1_orig/TopLevelProject.srcs/sources_1/bd/TopLevel/TopLevel.bd>
What I have to do to open the old Vivado 2017.4 project in Vivado 2020.1?
Thank you for your help.
BR
martin
msauerpb
Is in this forum no one who can help?
br
martin
joancab
The version has probably changed so you may need to:
- if you use a TCL script, change the version to the value in 2020 release.
- In the BD, drop the current MB core from the IP catalog
msauerpb
I can't open the bd. I always get this error message. I can't upgrade the microblaze core in my bd.
I have to manual change the version entry with a text editor in the bd file.
BR
martin
joancab
Do you create your BD with a TCL? In that case you should edit the TCL
msauerpb
I can't find an TCL file. There exist only the .BD file.
joancab
That's a problem, because Vivado can only import reliably BDs generated with its current release. Could you open/ import the original BD with the original Vivado release and from there, generate the TCL script? If you have already uninstalled it, an alternative could be start from scratch. I know...
