Process cannot have both a wait statement and a sensitivity list
Hi all,
I am in VHDL learning stage
When i am simulating test bench getting Process cannot have both a wait statement and a sensitivity list error
-- Company:
-- Engineer:
-- Create Date: 11:39:51 04/20/2019
-- Design Name:
-- Module Name: C:/Users/H335658/Desktop/test_bench/sdfwe/sdfwe_TB1.vhd
-- Project Name: sdfwe
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: sdfwe
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test. Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY sdfwe_TB1 IS
END sdfwe_TB1;
ARCHITECTURE behavior OF sdfwe_TB1 IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT sdfwe
PORT(
CLK1 : IN std_logic;
reset : IN std_logic;
CDbar : IN std_logic;
SDbar : IN std_logic;
Q : OUT std_logic;
Qbar : INOUT std_logic;
Q2 : INOUT std_logic;
Q2bar : INOUT std_logic;
Q3 : OUT std_logic;
Q3bar : INOUT std_logic;
BBbusyp : IN std_logic;
PPCLRn : IN std_logic;
clk10uP : IN std_logic;
LASTPTn : IN std_logic;
PTDONEn : IN std_logic;
clk1MHZ_1 : OUT std_logic;
CLK500K_1 : OUT std_logic;
CLK100K_1 : OUT std_logic;
CLK200_1 : OUT std_logic;
TR0p : OUT std_logic_vector(9 downto 0);
CTwrap : OUT std_logic;
q_out_1 : OUT std_logic
END COMPONENT;
--Inputs
signal CLK1 : std_logic := '0';
signal reset : std_logic := '1';
signal CDbar : std_logic := '0';
signal SDbar : std_logic := '1';
signal BBbusyp : std_logic := '0';
signal PPCLRn : std_logic := '0';
signal clk10uP : std_logic := '0';
signal LASTPTn : std_logic := '0';
signal PTDONEn : std_logic := '0';
signal flag : std_logic := '0';
signal counter : std_logic := '0';
signal sig_PHAS1An : std_logic := '0';
--BiDirs
signal Qbar : std_logic;
signal Q2 : std_logic;
signal Q2bar : std_logic;
signal Q3bar : std_logic;
--Outputs
signal Q : std_logic;
signal Q3 : std_logic;
signal clk1MHZ_1 : std_logic;
signal CLK500K_1 : std_logic;
signal CLK100K_1 : std_logic;
signal CLK200_1 : std_logic;
signal TR0p : std_logic_vector(9 downto 0);
signal CTwrap : std_logic;
signal q_out_1 : std_logic;
-- Clock period definitions
constant CLK1_period : time := 50 ns;
constant clk10uP_period : time := 20000 ns;
-- constant clk1MHZ_1_period : time := 10 ns;
-- constant CLK500K_1_period : time := 10 ns;
-- constant CLK100K_1_period : time := 10 ns;
-- constant CLK200_1_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: sdfwe PORT MAP (
CLK1 => CLK1,
reset => reset,
CDbar => CDbar,
SDbar => SDbar,
Q => Q,
Qbar => Qbar,
Q2 => Q2,
Q2bar => Q2bar,
Q3 => Q3,
Q3bar => Q3bar,
BBbusyp => BBbusyp,
PPCLRn => PPCLRn,
clk10uP => clk10uP,
LASTPTn => LASTPTn,
PTDONEn => PTDONEn,
clk1MHZ_1 => clk1MHZ_1,
CLK500K_1 => CLK500K_1,
CLK100K_1 => CLK100K_1,
CLK200_1 => CLK200_1,
TR0p => TR0p,
CTwrap => CTwrap,
q_out_1 => q_out_1
-- Clock process definitions
CLK1_process :process
begin
CLK1 <= '0';
wait for CLK1_period/2;
CLK1 <= '1';
end process;
clk10uP_process :process
begin
clk10uP <= '0';
wait for clk10uP_period/2;
clk10uP <= '1';
end process;
BBBUSYP_process :process(flag,BBbusyp)
begin
if(flag= '0') then
BBbusyp<= '0';
wait for 122 us;
flag <= '1';
else if (flag = '1') then
BBbusyp<= '1';
wait for 22 us;
BBbusyp<= '0';
wait for 166 us;
end if;
end process;
PTDONEn_process :process
begin
PTDONEn <= '1';
wait for 154.981 us;
PTDONEn <= '0';
wait for 0.019 us;
PTDONEn <= '1';
wait for 198.981 us;
PTDONEn <= '0';
wait for 0.019 us;
end process;
PPCLRn_process :process
begin
PPCLRn <= '0';
wait for 20 ns;
PPCLRn <= '1';
wait;
end process;
LASTPTn_process :process(counter,LASTPTn)
begin
if(counter<525) then
LASTPTn <= '0';
wait for 0.06 us;
LASTPTn <= '1';
wait for 0.14 us;
counter<= counter+1;
else if(counter = 525) then
counter <= 0;
LASTPTn <= '1';
wait for 16.54 us;
LASTPTn <= '0';
wait for 0.06 us;
LASTPTn <= '1';
wait for 16.54 us;
LASTPTn <= '0';
wait for 0.06 us;
LASTPTn <= '1';
wait for 16.54 us;
end if;
end process;
-- reset_process :process
-- begin
-- reset <= '1';
-- wait for 20 ns;
-- reset <= '0';
-- wait;
-- end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100 ns.
wait for 100 ns;
CDbar <= '1';
reset <= '0';
wait for CLK1_period*10;
-- insert stimulus here
wait;
end process;
END;
@siva407123_lak
Per the VHDL spec, you cannot (nor do you need) to have 'wait' and a sensitivity list.
The wait statement cannot be used:
  1. In a process with a sensitivity list
  2. In a procedure called from a process with a sensitivity list.
  3. In a function
  4. In a procedure called from a function
You may want to stimulate these processes with something the simulates a clock
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed. :-)
what is the intent of this
begin
if(flag= '0') then
BBbusyp<= '0';
wait for 122 us;
flag <= '1';
BBbusyp<= '1';
wait for 22 us;
BBbusyp<= '0';
wait for 166 us;
end if;
end process;
The Intent of this one is generating input pulse with different pulse width.
Attached reference.
please help me if any mistakes in code
siva
your in a test bench, which is behavioural,
do you need this to be synthesis-able ?
No,but how to generate clock with different time periods.
Intially i want time periode with 200ns(ton=140 ns and toff=60 ns,number cycles=525) then after ton =16.5 us,toff=60 ns like that it will repeat contineously  continuously
For your information i am attaching snapshot(secon signal)
yes
If you need it to be synthesised into a fpga,
how do you understand the delay 166 us to be implemented in the fpga logic?
@siva407123_lak,
Whereever you need, TB or Design, you must have two clock sources and do a MUXing.
If in TB: Simply MUX the two clk signals, as you would MUX two single bit digital signals.
If in Design (to be synth): Use the Xilinx BUFGMUX primitive to switch b/w two clocks. You need to play with Xilinx MMCM/PLL settings to generate the two clocks with your desired duty cycle.
FPGA enthusiast!
All PMs will be ignored
