fkhalili
Question about Vivado 2016.3 custom Master AXI Stream Interface generator.
Hello All,
I have generated a Master AXI Stream by Vivado 2016.3 IP packager tool. I suppose something is wrong here. If anybody noticed this, please reply this. Here is a snippet of generated VHDL:
constant NUMBER_OF_OUTPUT_WORDS : integer := 8;
constant depth : integer := NUMBER_OF_OUTPUT_WORDS;
constant bit_num : integer := clogb2(depth);  -- Based on the "clogb2" function, the value of bit_num = 4;
here is the "clogb2" function:
-- function called clogb2 that returns an integer which has the
-- value of the ceiling of the log base 2.
function clogb2 (bit_depth : integer) return integer is
        variable depth : integer := bit_depth;
        variable count : integer := 1;
        begin
             for clogb2 in 1 to bit_depth loop -- Works for up to 32 bit integers
                  if (bit_depth <= 2) then
                       count := 1;
                  else
                       if(depth <= 1) then
                              count := count;
                       else
                              depth := depth / 2;
                              count := count + 1;
                       end if;
                 end if;
            end loop;
  return(count);
end;
signal read_pointer : integer range 0 to bit_num-1;  -- In this line the range for "read_pointer" would be from 0 to 3!
In the body of code following condition has been applied which I suppose it violates the range of "read_pointer".
axis_tlast <= '1' when (read_pointer = NUMBER_OF_OUTPUT_WORDS-1) else '0';
Please correct me if I am wrong. Thanks
fkhm
howardp
It appears the range of read_pointer is declared incorrectly.
The value of NUMBER_OF_OUTPUT_WORDS =8.
The range of read_pointer should be 0 to 7 (0 to NUMBER_OF_OUTPUT_WORDS-1).
However, it is written as:
Because bit_num = clogb2(NUMBER_OF_OUTPUT_WORDS), this incorrectly makes the range of read_pointer 0 to 3.
If the project language is changed to Verilog and the same steps applied, the Verilog declaration of read_pointer is:
     reg [bit_num-1:0] read_pointer;
Which correctly allows values from 0 to 7.
I've filed a change request to get this fixed for VHDL.
fkhalili
Hi Again!
Why nobody reply to this? :(
howardp
fkhalili
Hello @howardp
Yes! Exactly, That was what I meant to mention. Thank you for your message :).  Since I am using 2016.3 version, I have no idea if this happens also in latest versions or not. Anyway, I would have liked to report this situation.
Farnam
cahitugur
Same problem with the AXI Slave interface template in Vivado 2018.2,
-- bit_num gives the minimum number of bits needed to address 'NUMBER_OF_INPUT_WORDS' size of FIFO.
constant bit_num  : integer := clogb2(NUMBER_OF_INPUT_WORDS-1);
although the range of the bit_num is explained correctly in the comment.
The embarrassingthing for Xilinx is this bug still exists after 7 Vivado releases!!!
Incredible!!!
