Re: Vivado IP netlist created for ISE use?
hi, i just generated one block_memory_geneartion IP in vivado, and want to get the netlist(*.edf) of this IP, export and run synthsize in third-party tools, i know if we synthesis one design based on HDL file, then we can open synthesized design -> tcl: write_edif to generate the netlist file, but currently, in vivado, no HDL file except the *.xci file is in the design source, if i don't want to wrapper this ip with HDL file, can i get the netlist file in another way? btw, i found in *.dcp file, there is one *.edf, can i directly take this one?
Hi @winfredw
Did that help?
Deepika.
Deepika.
In Design runs tab you can see IP OOC synthesis run. Right click on this and select "open run" this opens IP synthesized design where you can write EDIF using write_edif.
Yes, you can also use EDIF file located in DCP.
Deepika.
Deepika.
Hi @winfredw
Did that help?
Deepika.
Deepika.
hi @vemulad, thanks for your confirm, and i have also wroked with it, and it works.
