Observer jfcliche
Re: Vivado synthesis slower than XST?
Hello all,
I've just tried the new Vivado 2013.2 and the Managed IP flow which pre-synthesizes the cores into a checkpoint (.dcp) file.  On a small design, synthesis time was cut by half. I would expect an even bigger gain on a big design that reuse cores many times. This might be the solution I was looking for. I still have synthesis messages like
WARNING: [IP_Flow 19-2162] IP 'clock_mmcm' is locked. Locked reason: User override
and
Xilinx IP preload is disabled
and I don't know if they have any implication on the synthesis speed but I'm working on it.
Hope this helps,
JF
one quick check. Compare the utilization (sysntehsis reports) in ISE and Vivado. This can give some clue.
Deepika.
Deepika.
Visitor binupr
Can you explain how ti disable "IP Preload" in Vivado 2013.2?
Visitor binupr
I just figured it out :
Project Manager--> Project Settings--> IP-> Packager(Tab)-->Automatic Behaviour--> Untick 'Run -upgrade_core when opening IP Packager'
