Re-generate Verilog module from xci
I have an xci file for an axi_interconnect IP block from an open source design but not the verilog module to include in RTL compiilation.  How do I generate the module definition so I can use it for synthesis/simulation?
Hi @petemar
  When regenerating the output products, you should be getting the stubs and necessary files for synthesis/implementation.
 The design checkpoint (.dcp) contains the synthesized netlist in .edf form and stub, if needed.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
Hi @petemar
Check the directory in which the output products of the IP are present.
I inherited this project and the directory is empty.  All I have are the xci files, which are attached.
Hi @petemar
  Have you tried adding the .xci files to the project, and then generating the output products for them?
-Pat
I did that and was able to get the instantiation template. However, I need to get the verilog stub and associated ngc/edf to get through synthesis and P&R. How can I get those?
Hi @petemar
-Pat
Got it. Thanks, Pat!
