Refreshing IP repository takes 17 minutes from 2017.2 to 2019.1
I has been suffering from an annolying bugs regarding "refresh ip repository". I have a design with several block diagrams and hls IPs. Our typical design flow is to 1) change hls code, resynthesize and export ip, 2) update IP in vivado project. However, since 2017.2 (2019.1 has the same problem), when I click on "refresh ip repository" after making change to hls IP, it sometimes take 17 minutes to finish. I am using Ubuntu 18.04 and I don't remember this long delay with 2015.x. Change in both HLS core and RTL core has the same behavior in terms of delay. Please let me know if there is anything to try or debug.
Jimmy
Re: Refreshing IP repository takes 17 minutes from 2017.2 to 2019.1
@linzhongduo
Can you share the archive project from 2019.1? If yes, I will send you private message which has ftp link to share the project.
--Syed
Hi @syedz ,
OK, please send me the link.
Jimmy
Hi @syedz ,
Are you able to reproduce the problem?
Jimmy
