Observer joelschad
Repackaging IP for different project and different FPGA
I am migrating a design from a ZYNQ 7000 to a ZYNQ UltraScale+ in Vivado 2018.3, and one IP block was designed in-house (not by me) for the older 7000 design.
If I follow the IP Packaging wizard, my IP will show in the US+ project, but it does not pass validation. If I just copy the folder from the 7000 project to the US+, same result.
How do I configure a given piece of HDL for a specific FPGA prior to packaging?
Observer joelschad
Re: Repackaging IP for different project and different FPGA
This worked, so thank you.
I also found that if the IP was not set up for compatibility with the processing system your project is using (7000, UltraScale+, etc.), you can't see the IP in the IP Catalog (since it's not yet compatible), so you can't add it to your block diagram to Edit in IP Packager.
I set up another project in another instance of Vivado using the previous processing system (in my case, a ZYNQ 7000). Because the IP blocks were available in this project, I could edit them in Edit in IP Packager, which allowed me to add US+ to their compatibility lists.
After repackaging them, I went back to my US+ project/instance of Vivado, refreshed my repos in the IP Settings screen, and the IP blocks were now available to me.
Hi @joelschad ,
You need to edit the IP(custom IP) and re-customize it for required devices and then add the repo and it will work as per your requirement.
Raj
Observer joelschad
