Revision Control for Vivado projects
Hi All,
I'd like to start using the Revision Control for Vivado projects under Linux. What's the recommended flow? What files should be put under revision control?
Thank you!
Re: Revision Control for Vivado projects
check if the following link helps there are script for windows but you will need to modify for linux
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug1198-vivado-revision-control-tutorial.pdf
Yes, these scripts are for Windows, not for Linux...
Is there a way to receive the scripts for Linux?
As for Linux, should the scripts be ran from inside of Vivado? Could they be implemented in such way so that they could be ran from Linux commands prompt (outside of Vivado)?
Thank you
check this post
https://forums.xilinx.com/t5/Design-Entry/Vivado-and-version-control/td-p/347941
Thanks and Regards
Balkrishan
