Participant tarthon
Run Vivado as Administrator -
# An unexpected error has occurred (EXCEPTION_ACCESS_VIOLATION)
Stack:
no stack trace available, please use hs_err_<pid>.dmp instead.
I can't run Vivado as administrator.
Is this a known problem, or is something else wrong with my setup?
Re: Run Vivado as Administrator -
Hello @tarthon
Try these steps:
1. Open Vivado in Tcl mode i.e., command: vivado -mode tcl
2. Open Vivado in 32-bit model. Command: vivado -m32
3. Open Vivado using the command: vivado -jvm Xmx4096m
Which OS are you using? What is Vivado version?
Share the created hs_err_<pid>.dmp file here to debug the issue.
Vinay
Participant tarthon
Attached are the logs/dmp files!
Participant tarthon
I tried to run -mode tcl, still got errors.
I ran -m32, and compiled 32 bit libraries: Failed also.
vivado -jvm Xmx4096m: failed.
