Observer thomasmurphyge
Running "Update Board Repositories" in Project Creation Hangs with Filtered Network Connection
In Vivado 2019.1, there is an option to "Update Board Repositories" provided in the New Project wizard interface. If the "Download" button is clicked when behind an SSL-intercept firewall/proxy (typically from a corporate network, as is my case), the connection to the Github repository fails and the dialog locks up the whole Vivado instance. The "Downloading Boards" status window cannot be canceled nor closed. A screenshot of this state is attached to this post.
Is there a way to manually retrieve and store the data in Vivado from https://github.com/Xilinx/XilinxBoardStore? Can this interface be updated to prevent locking up Vivado on certain failed network states?
Re: Running "Update Board Repositories" in Project Creation Hangs with Filtered Network Connection
Hi @thomasmurphyge ,
I think you should be able to install the boards by using the tcl commands given on the wiki page. Please let me know if it doesn't work atyour end.
~Chinmay
~Chinmay
In case anyone else has this problem.
Had the same issue, my problem was that the board repository on windows is stored in the C:\Users\"Windows User Name"\AppData\Roaming\Xilinx\Vivado\20xx.x\xhub\board_store, as my windows username contains a Space vivado will fail when looking up the Path.
Solution was uninstalling the board repo
xhub::uninstall [xhub::get_xitems]
Changing the repo path
set_param board.repoPaths path-without-space
Then reinstalling the repo
xhub::refresh_catalog [xhub::get_xstores xilinx_board_store]
xhub::install [xhub::get_xitems]
