szohar
SDK 2016.2 running very slow
I am having an issue running on Windows 10 with SDK version 2016.2
Other engineers that are working on the same C code on Windows 10 and Windows 7 will compile all the code in less than 7 minutes, my computer is using a faster CPU with more memory and will take over 2.5 hours. I checked the CPU and the memory and saw very low usage.
I tried all the ideas in the forums but nothing helps.
Your help will be greatly appropriated.
