cvasantha
SDK is getting closed sometimes
   I am using Vivado 2018.2 version. When i was using SDK sometimes it was getting closed and going to background tasks. Is there any issue in my installation process or it's a real problem from xilinx side.
chinmays
Hi @cvasantha,
Which Operating system and built are you using ? Do you observe this issue while launching sdk from inside of Vivado or through standalone mode also ?
regards,
Chinmay
cvasantha
Hi Chinmays,
Its Windows 10 OS and configuration is 8GB RAM. I didn't use much In Standalone mode. Most of the times from Vivado only i used launch. From Vivado launch i am getting this issue.
