tuancao
SDx 2016 cannot build project in WIN7 64bit
+ I have create a tutorial project about FIR (available in SDx) same as the tutorial GUIDE.
+ I lick build to check the result, however the sds++.bat got problem as below:
Inline image 1
Should I need to set any environment variable?
My current path is: "C:\Windows\System32;C:\Windows;C:\Program Files\MATLAB\R2016a\bin;C:\Program Files (x86)\Skype\Phone\;C:\Xilinx\SDx\2016.4\bin;C:\Xilinx\SDx\2016.4\SDK\bin;C:\Xilinx\SDx\2016.4\Vivado_HLS\bin;C:\Xilinx\SDx\2016.4\gnu\binutils\bin;C:\Program Files (x86)\OpenVPN\bin;C:\Program Files\VisualSVN Server\bin-KM"
Thank you in advance.
tuancao
I have solved this problem.
open cmd window
type following command:
set PATH=
cd C:\Xilinx\SDx\2016.4
.settings64-SDx.bat
cd bin
sdx.vbs
After that, enjoy SDx :D
wolff000
Thank you very much for posting the solution!!!  Your fix worked for me as well.
