Sample Vivado tri_mode_ethernet_mac
Can someone point me to a sample design in Vivado for the tri_mode_ethernet_mac? I want to see how to hook it up.
Re: Sample Vivado tri_mode_ethernet_mac
Hi tphelan@miyachiamerica.com ,
How to open tri mode ethernet mac IP example design:
Steps:
Open a Vivado project - add tri mode ethernet mac IP from IP catalog and do OOC synthesis of it.
Then right click on it and select Open IP Example design.
hemangd
Scholar dpaul24
tphelan@miyachiamerica.com,
Please read the latest version of PG051 docu, Chapter5 and Chapter6. Detailed info is given there.
FPGA enthusiast!
All PMs will be ignored
Thank you for the above inputs.
I don't find the user documentation particularly user friendly and the method described to create a sample project created a HDL rather than a block design. I should have been more specific in my request. Nevertheless your feedbacks are appreciated.
To be more specific I have a Zynq 7000 based design which already has two Ethernet ports instantiated. I need a third. So I have elected to use the TRI_MODE_ETHERNET IP. How to hook up to the memory interface and the streaming port of the Ethernet block, whether I need to use a FIFO or not, is not clear to me. I will continue my study on this and thank you again for your suggestions.
You may want to check out the AXI Ethernet Subsystem then which is a higher level than the TEMAC itself but uses the TEMAC under the hood:
https://www.xilinx.com/products/intellectual-property/axi_ethernet.html
pg138 instead of pg051
If you are looking for a Zynq-7000 example where they was used, there's a few including:
http://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf (PS and PL Ethernet Performance and Jumbo Frame Support with PL Ethernet in the Zynq-7000 AP SoC)
https://ethernetfmc.com/exampledesigns/
Those are probably a bit closer to what you are looking for...
Cheers,
bt
