Select device in vivado2013.3
Hello
I develop application with device XC7Z030-1FBG676I in Vivado design suite 2013.3
I can't find FPGA XC7Z030-1FBG676I in Select Device window in Vivado. I found only xc7z030fbg676-1 in temperature grade C (not I) and xq7z030rf676-1I  in temperature grade I. My application is very time critical about 0.1ns WNS. The right selection FPGA device is important for me because I want to have the timing analysis trustful and correct.
Can you please help me with this problem? See below.
Thank you and Regards.
Re: Select device in vivado2013.3
you may also check this link http://www.xilinx.com/support/answers/38221.htm
Deepika.
Deepika.
How you developed the application on this device?
As this device is available in C grade.
A change request already exists on this issue. This is planned to be fixed for 8 series devices. For 7 series, select the required part using 'C' (Commercial) Temp grade.
Here is an informative article:
http://www.xilinx.com/support/answers/54561.htm
Deepika.
Deepika.
Thank you very much for all.
Josef
