Set output directory for generated products
This question is for both project and non-project flow in Vivado 2015.1.
I would like to keep my .xci files in a different set of directories than all the generated outputs. I looked through the GUI and I don't see any setting anywhere but maybe I missed it. On the TCL level, it does not seem like generate_target can take an output directory, but maybe there is a property/setting somewhere?
Is this possible? Ideally I would like to keep my sources directory read-only from the point of view of Vivado in both project and non-project flow.
Yuriy
Tags (3)
@yromanenko
In vivado tcl console type.
create_ip -help. This will give you all the options available for the create_ip, it should have -dir option to create ip.xci file in the specified directory.
-Pratham
That would let me create an .xci file in an arbitrary location. However, I would like to treat an .xci file as an INPUT that is checked into revision control, to be compatible with both project and non-project flow. If I keep all my IP as .tcl scripts that call "create_ip -dir" then there is no way to be compatible with project flow.
I would also like to have the generated output files and the XCI file in separate folders to ease revision control setup.
@Xilinx:  is there any way to do that? (preferably wihout re-creating the IPs)
(that is also a solution if I can change a field in the XCI file manually ;)  )
I hope to have a quick feedback.
regards,
  Andras
@pratham:
do you have any suggestions for this issue?
thanks,
  Andras
hi all,
I could solve the issue ... partly.
after this thread was ignored by Xilinx :( , I started to poke around the XCI files.
it is not that complicated, after all :)
the last 2 lines of every IP generated by Vivado is always the same:
        <spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.OUTPUTDIR">.</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SHAREDDIR">.</spirit:configurableElementValue>
I simply changed this to a new folder of my chosing:
        <spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.OUTPUTDIR">../../../ip_tmp</spirit:configurableElementValue>
        <spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SHAREDDIR">../../../ip_tmp</spirit:configurableElementValue>
The only thing that I came across is that if you are using the XCI files only for revision control, then you needto keep the folder hierarchy from Vivado: <IP folder>/clk_wiz0/clk_wiz.xci .
You should not move the xci file 1 hierarchy up, because then (if you have other IPs) the generated output files can be messed up.
And that is because nevertheless I changed the OUTPUTDIR and SHAREDDIR value, Vivado is nice enough to still produce some files next to the XCI file. (.dcp, _funcsim.v, _stub.v, ...)
Anyhow, this works for me, although I would have wished a bit more seamless solution...
