Setting CONFIG_VOLTAGE and CFGBVS using Vivado 2014.1 GUI
Is there a way to set the CONFIG_VOLTAGE and CFGBVS for a design using the Vivado GUI?  The DRC for my design complains about these two not being set.
Re: Setting CONFIG_VOLTAGE and CFGBVS using Vivado 2014.1 GUI
Thank you for the reply.
I discovered within the Vivado GUI under Tools -> Edit Device properties -> Configuration that you can enter the settings for the configuration voltage and configuration bank voltage selection settings here.
You can set them through TCL command, Please refer UG899 Page -33.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_4/ug899-vivado-io-clock-planning.pdf
Hope this helps
Vanitha
FYI: You can also set CFGBVS by XDC options
Ffor CFGBVS and CONFIG_VOLTAGE  as:
set_property CFGBVS Vcco [current_design]
set_property config_voltage 2.5 [current_design]
The options for CFGBVS are VCCO or GND.
The options for config_voltage are 1.8/2.4/3.3
Please MARK as an answer in case if any post/posts helped to resolve/answer your query. Give kudos in case the post guided/gives useful information
Hi David,
Please close this thread by marking the answer.
Deepika.
Deepika.
Visitor hearmenow
I would like to add that the path to this is RTL Analysis>Elaborated Design, then Edit Device Properties will show up in the Tools pull down.
