10-22-2020 12:53 PM
Is there a 2019 version of the Si5324 example project? I've downloaded the 2015 version
and follow this
But I have some errors when I run synthesis and I think the reason could be that is written whith an older vivado version
[Synth 8-5809] Error generated from encrypted envelope. ["c:/Users/Diego/Documents/Fiuna/LME/Link test/AC701/ac701_si5324/ac701_si5324.srcs/sources_1/ipshared/xilinx.com/blk_mem_gen_v8_2/834889ee/hdl/blk_mem_gen_v8_2_vhsyn_rfs.vhd":4692]
10-26-2020 09:34 AM
Hi @daranda314
The menu option Reports/Report IP Status shows all the IP status and offers to upgrade the selected IPs with a button.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
10-24-2020 08:50 PM
Hi @daranda314
I took the .zip file linked in your post and opened it with Vivado 2019.2.1, and after upgrading all the IP's, it synthesized without problems. There were some warnings in the IP update process, but didn't cause issues.
I also ran implementation & bitstream generation which completed as well.
-Pat
10-26-2020 09:22 AM
10-26-2020 09:34 AM
Hi @daranda314
-Pat
10-26-2020 09:41 AM
