Simple up counter fail to run
Hello all,
Here is a small test counter code in verilog:
`timescale 1ns / 1ps
module TestCounter2(
    out_count,
    clk
    output [7:0] out_count;
    input  clk;
    reg [7:0] out_count;
    always @ (posedge clk)
    begin
        out_count <= out_count + 1;
    end
endmodule
I am generating a bitstream for this code to be programmed for a custom zynq 7000 board. I have connected the output to ILA and given a clock input from PS7 FCLK_CLK0 set for 100 Mhz.
Below if screen shot of the output seen on hw_ila in vivado
output from hw_ilaoutput from hw_ila
There is no count increment as expected.
Can you please help me to identify the issue.
Thank you in advance.
The clock FCLK_CLK0 is not toggling on the screenshot and is lock to 1.
Did you check signals FCLK_CLK0 and clk of your module are toggling ?
It looks locked to one because the ILA is sampling at same rate (i.e., 100 MHz) as the clock FCLK_CLK0 and I assume it is only capturing the rising edges of the clock.
Using a simple binary counter IP, i saw that the clock is toggling based on the output from counter which was always incrementing.
