Visitor emiele
Spartan 1 Tools for synthesis not in ISE 4.2, alternatives?
One of our older devices appears to have a bug that would need fixing. The device uses a SPARTAN 1 XCS20.
The last ISE version to support this FPGA is ISE 4.2, but there are still a few problems I have.
1) A new project doesn't allow for the design flow to be set as XST VHDL, only as EDIF. This makes it impossible for me to create a usable project.
2) There appears to be no way to compile or synthesize a project using ISE 4.2. Are there any free/paid solutions you can point me too? The program used over more then 17 years ago was Synopsis.
This question boils to the following. I need to be able to write and use code for an old SPARTAN 1, but I cannot find the right software for that.
Emiel
Visitor emiele
Re: Spartan 1 Tools for synthesis not in ISE 4.2, alternatives?
Just to wrap this up,
LeonardoSpectrum from Mentor Graphics supports this chip. The software is not free, but works.
Teacher drjohnsmith
I dont know , but a thought.
Back in those days, a lot was made using schematic capture,
    and I think it was Simplify,
So you could be looking for schematics to modify,
   it was a very different world then ,
      you might want to find some one that used the tools back then
Mentor jmcclusk
Mentor
It should be possible to use a later version of ISE that includes XST, targeting a Spartan 2 device..   Extract the EDIF from the XST output, and use it as a design source for ISE 4.2 targeting the Spartan XCS20
Visitor emiele
Thank you, I will try this after the weekend. I'm curious how this will work, since both are obviously different chips. This will not work for a Spartan 3 I guess?
Any other suggestions are still welcome.
Teacher drjohnsmith
Also, It might be a Xilinx foundation based project, I had a quick look at some old notes and it looks like I was using that for spartan (1) as they are now called.
Visitor emiele
Hi, can you tell me what the project file extension is called on these old projects?
Teacher drjohnsmith
sorry , long time ago,
I do remember that Aldec used to supply the schematic tools for Xilinx,
I've just done a quick search and bumped into this
https://www.aldec.com/en/support/resources/documentation/faq/1193
might be worth while chasing
Visitor emiele
Hello again,
I tried this, and successfully extracted the EDIF and opened it in ISE 4.2. As a testing project I implemented a simple AND gate.
When I want to implement the design however, I first receive a warning:
WARNING:NgdBuild:486 - Attribute "INIT" is not allowed on symbol "C1" of type "LUT2". This attribute will be ignored.
Followed by an error:
ERROR:NgdBuild:604 - logical block 'C1' with type 'LUT2' is unexpanded. Symbol 'LUT2' is not supported in target 'spartan'.
It's seems like the naming of the primitives is different. I've been thinking of changing the names in the EDIF, but I cannot find the name of the primitive in the xcs20. This will also be very tedios and this is only a single AND gate...
Am I doing something wrong? The Spartan 2 I chose was a XC2S15.
Emiel
Teacher drjohnsmith
Your in a world of pain,,
I seem to 'remember; that the original Spartans had _LUT, B_LUT and C_LUT in each CLB
its a long time ago so sorry not more specific.
The tools changed greatly between spartan and spartan 2,
BTW: Have you had search around, some one a few years ago had a similar set of questions,
    its unusual enough that I wonder if ts the same company !
Visitor emiele
Yeah, it's almost impossible. I have come across other threads similar, but none offer a solution, or they are hidden behind 404 links. We're not the same company.
You are correct, that's what the lut's are called, however that doesn't seem to translate to the netlist verry wel.
ISE 2.1 seems like what I need. But is unavailable, except from a few books on ebay/amazon, but those are student licences.
I also wonder why ISE 3.3 service packs are available for download, but not ISE 3.3 itself?
Teacher drjohnsmith
About this time, Xilxin changed tool suppliers,
Have a look at the Aldec web site, see if there tools can read the files in
Last option, is go back to the backup / archive tapes of the prject,
     install a virtual windows XP machine,and re instate the files form backup
good luck,
Visitor emiele
Visitor david.rios
Hello Emiele,
What is the cost of leonardospectrum?
were did you buy it?
Thanks!
Best regards
David R.
