schambachjj
Suppress RTL Hierarchical Component Statistics
I am running Vivado in batch mode inside a "continuous integration" (CI) and recently ran into the log message limit of the CI. Looking at the log messages, I see thousands of messages under the heading "Start RTL Hierarchical Component Statistics" that seem mostly informational, so I don't really care about those messages. How can I suppress these messages with set_msg_config?
schambachjj
PS: Here is what the messages look like
Module xpm_cdc_single__71
	                2 Bit    Registers := 1
Module xpm_cdc_single__72
Module xpm_cdc_single__73
Module clock_switch_fsm__1
	   6 Input    2 Bit        Muxes := 1
	   4 Input    1 Bit        Muxes := 2
	   2 Input    1 Bit        Muxes := 1
Module clock_switch_fsm__2
richardhead
There is the set_msg_config  tcl command that allows you suppress any numbered message. But I think the message you are trying to suppress are from the .log file and I dont know if they can be suppressed.
We run gitlab and have had to increase the log limit from the default 8mb to 20mb to cope with the huge vomit of logging that spews from vivado.
in my "quick compile and elaborate" job, I do this to keep the log as quiet as possible:
set_msg_config -severity STATUS   -suppress
set_msg_config -severity INFO     -suppress
set_msg_config -severity WARNING  -suppress
