honghuynh
[Synth 8-5809] Error generated from encrypted envelope
I got the " [Synth 8-5809] Error generated from encrypted envelope " error message during the design sysnthesis. The error point to the encrypted UHD-SDI design file.
What could be the problem?
Hong
yangc
Hi @honghuynh ,
Could you send your design to us? And tell us your vivado version , OS .
There are a couple of causes , maybe you can refer to below :
https://forums.xilinx.com/t5/Synthesis/FIFO-generator-v13-2-2-synthesis/m-p/889733
And you can search "[Synth 8-5809] Error" in the forums to find the solution which suitabloe for you.
viviany
Is the nidru_20_wrapper.vhd a user source file or a file from IP?
On Line 126 in this file, is it the instantiation of an encrypted IP instance?
The issue may be with some error in the port mapping of this IP instantiation, such as, type mismatch, width mismatch, missing port name, incorrect port name and etc.
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
honghuynh
Hi Yang & Vivian,
Thanks for your responses.
I am currently OoO.
I will look into your responses when I am back next Monday.
Hong
honghuynh
Hi Vivian,
The nidru_20_wrapper.vhd is file from the IP core.
I don't think the error is due to any of the one you listed since the earlier version of the same project compile w/o any issue.
Since I was able to use the earlier version, let's close this issue for now. We can reopen it when the problem arises.
Hong
