[SystemVerilog] generate for assign -> why doesn't work?
Hi All,
I'm receiving the "[Synth 8-2599] range is not allowed in a prefix" error message for the following code:
genvar i;
generate for (i=0; i<5; i=i+1) begin
    assign mem_data[15:0][i] = tg_data[15:0][i];
  end
endgenerate
Why?
Here are the signal declarations:
wire [15:0] tg_data [15:0]
output [15:0] mem_data [15:0]
Could the generate statement be used for assign statement? How? Please provide an example.
Thank you
Guide
Guide
This has nothing to do with the generate statement, the base assign statement is illegal
assign mem_data[15:0][0] = tg_data[15:0][0];
This is attempting to tie the least significant bit of all 16 words of mem_data to bit 0 of all 16 words of tg_data.
I am not sure what you are trying to do with your loop - tie the LSB 5 bits of all 16 words together? If so, then turn the loop around
genvar i;
generate for (i=0; i<16; i=i+1) begin
    assign mem_data[i][4:0] = tg_data[i][4:0];
  end
endgenerate
 (But this seems like really weird code to do in an assign - what are you expecting to happen to the remaining 11 bits of each of the 16 words - are you going to 'assign' them in another process?)
Avrum
