SystemVerilog import VHDL package error
I have a SystemVerilog (.sv) testbench that instantiates VHDL (.vhd) design files. In the testbench, I need to use a record defintion from a VHDL package file. When I try to import pkg::*; in the .sv testbench, Vivado gives an error during compilation:
xvlog -m64 --relax -prj sw_tb_vlog.prj
INFO: [VRFC 10-2263] Analyzing SystemVerilog file "tb.sv" into library xil_defaultlib
ERROR: [VRFC 10-91] pkg is not declared [tb.sv:3]
I changed the compile order in the Vivado window so the pkg.vhd file is compiled before tb.sv, however this error still persists. I've also tried `including the .vhd package file instead of importing, however that generates a syntax error as they are different language files.
Any ideas?
Re: SystemVerilog import VHDL package error
Hi @marver
Can you please post simple code that demonstrates your usage for better understanding?
Thanks,Vijay
Hi @vijayak,
  Here's a snippet of tb.sv
`timescale 1ps/100fs
import pkg::*;
module tb;
  local_bus_record sys_ctrl_bus;
endmodule
and here's a snippet of the pkg.vhd file
library ieee;
use ieee.std_logic_1164.all;
package pkg is
  type local_bus_record is record
    reg_ack  : std_logic;
    reg_data : std_logic_vector(31 downto 0);
  end record local_bus_record;
end;
Hi @marver
I am able to reproduce the issue with Vivado and seeing the same issue with Questa as well.
I will get back to you soon on this.
Thanks,Vijay
What was the solution/outcome here? I'm having an identical issue in 2016.2
Is there a solution to that problem yet?
and in general - how well xilinx tools work both with VHDL and Verilog/SystemVerilog files?
oft
