TCL: How to create constraint for a interface from board file (XML)
I want to use a TCL script in my IP to create a constraint for a specific board and interface.
The TCL script should source the board file and extract the interface, name, iostandard and pin location..
Where should I start?
Thanks in advance!
Now I have a working TCL script.
When I use the TCL console and source the file before opt_design, place_design and route_design,
the build (synthesis) steps work without problems.
But I don't get it work in GUI.
IP:
Can somebody tell me the correct settings for the TCL constraint in the IP, to get it work in a top level design?
