TTL outputs
I have designed an FPGA and the outputs of the FPGA goes to the inputs of a DAQ that has TTL inputs
I have constrained my outputs this way but i'm not sure if it is the right way?
set_property IOSTANDARD <LVTTL> [get_ports <ports>]
Historian
Historian
Re: TTL outputs
Just to be clear - the constraint is
set_property IOSTANDARD LVTTL [get_ports <ports>]
The name of the IOSTANDARD "LVTTL" is not put in <> - the <ports> is intended to represent a string that is the name of the ports to which this property is to be applied, but the LVTTL is an actual string.
If it is more than one port, then the get_ports must be in quotes either
set_property IOSTANDARD LVTTL [get_ports {<port1> <port2> <port3>}]
or
set_property IOSTANDARD LVTTL [get_ports "<port1> <port2> <port3>"]
Avrum
Re: TTL outputs
Hello Lebowski,
Each device family has many different IO Standards that are supported.  For example, Kintex UltraScale (https://www.xilinx.com/support/documentation/data_sheets/ds892-kintex-ultrascale-data-sheet.pdf) datasheet, page 12, has a list of the supported IO standards.  THe LVTTL IO Standard is listed for this device family.
Your XDC constraint syntax is also correct.
Good Luck,
Chris
Historian
Historian
Re: TTL outputs
or
Avrum
Re: TTL outputs
Thank you!
Re: TTL outputs
Hello @lebowski,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
