Transfer a project from one chip to another
Hello guys,
I have a very simple question but in essence, it needs complete understanding.
I wanna know what is the procedure and principles that must care about moving a project (which is designed for a specific Xilinx chip and board) to another chip and board (the same family of chips, for example, UltraScale+ family). I couldn't find any specific paradigm to explain what's the important steps.
I appreciate any help.
@sahebi.amin
Your pure HDL (eg. VHDL or Verilog) will be portable to different devices.  Things that may not be portable are:
1) instantiation of things from the device Libraries Guide (eg. UG974
2) instantiations of Xilinx IP
3) many things in the project constraints (.XDC) file  - especially physical constraints
-and, you must ensure that the new device has at least as many used resources (eg. IO, slices, RAM, DSP, GTP tranceivers) as the old device (eg. see UltraScale+ Selection Guide).
Mark
Dear markg@prosensing.com ,
Many thanks for your quick reply,
I didn't care about device libraries, I will try and will back to you.
