Scholar ronnywebers
Tutorial on using multiple (sub) block designs in a single project
Is there any tutorial available that shows how to split up a design into multiple (sub) block designs, and combining these into a single toplevel (bd) design?
I've read that hardware-handoff would not work properly in this case, has this been solved yet in Vivado 2015.2?
I've been experimenting, but parameter propagation, address mapping, ... behaved strange, so I gave up. However it would make design reuse much more practical, and toplevel designs more manageable.
Re: Tutorial on using multiple (sub) block designs in a single project
Check this link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_2/ug994-vivado-ip-subsystems.pdf
Nupur
Nupur
