UG1198 v2016.3 Lab 6 Files Not Revision Controlled
Lab 6 of UG1192 v2016.3 Vivado Design Suite Tutorial: Revision Control pg. 30 states:
"Just as in the prior labs, you will automate the generation of the top-level design, and place necessary files under revision control."
However, after completing lab 6, I found no instructions on revision controlling any files in lab 6.  What files are suppose to be revision controlled in the top-level integration?
Best Regards,
Joseph
You are correct, the sentence appears to be incorrect.  In this lab you do not place files under revision control.  You are only using the files that are currently under revision control.
That following sentences would be more correct
Just as in the prior labs, you will automate the generation of the top-level design.  The design will source files already under revision control.
