anusheel
UltraFast Design Methodology Overview – Starting Points
Xilinx has created comprehensive UltraFast Design Methodology Guides that cover key principles, specific do's and don'ts, best practices, and ways to avoid pitfalls. In some topics, Xilinx provide real life use cases to illustrate concepts. The methodologies presented is a reflection of user experiences and learning gained from system development inside and outside of Xilinx.
The Design Creation section outlines the best practices for adding IOs and clocking elements of the design, and registering logical boundaries, to ease in timing closure and functional debugging of the design.  It also outlines the use cases of working with IP, including the selection and customization of the IP.
Download the new UltraFast High-Level Design Methodology Guide today!
