Participant aoliveri2
Unhide clock and reset in vivado diagram
How is it possible to unhide reset and clock signals when a connection is made in a block design?
Re: Unhide clock and reset in vivado diagram
If you go to the Design Tab and expand the Nets folder, you can find a signal, right-click, Disconnect...  If the signal is completely disconnected, it will reappear on the ip core block in the diagram again. This would most likely be undesirable in the case of clocks and reset outputs/drivers.
The original intent was to connect a reset input to another source.  To do so do the Disconnect.  It should reappear on the block.  Right-click the input just disconnected then Connect...  select the new source for the input signal.
