Unisim Installation
Good day,
When I start synthesize process, I get an error  "Cannot find <vpkg> in library <unisim>. Please ensure that the library was compiled.............etc.
I've performed a process "Compile HDL Simulation Libraries".
What should I do to fix the problem?
Thank you in advance.
Re: Unisim Installation
That package is not synthesizable.  Without more context of how your project is setup, it's hard to tell exactly what you need to do to resolve it.  If you are using the core, make sure the XCO file is in your project for synthesis rather than the HDL simulation wrapper.
