CT
Updating XPM memories with updatemem
Hello, I am currently having an issue with populating BRAM modules using updatemem. I have 8 RAMB36 modules and one RAMB18 module for my 8192x38 ROM module.
But when I run updatemem, only the first 1024 lines are populated. The rest are set as 0. I receive the critical warning:
CRITICAL WARNING: [Memdata 28-315] The input data file has exceeded 32768 which is the maximum number of bits for a RAMB36 primitive. The updating of the BRAM init string is terminated. Please check your input data file.
I tried using the patch suggested in https://www.xilinx.com/support/answers/76441.html but I receive the same critical warning except it is now for the RAMB16 module. I am using ProtoCompiler O-2018.09-4-patch and Vivado 2018.1 to generate the base bit file and using Vivado 2020.2 to run updatemem.
ansarimo
Is your XPM memory cascaded? If yes, then you will face this issue in 2020.2.
For cascaded XPM memory, this is a known issue that will get resolved in the later release of Vivado, instead of using updatemem flow you can use the MEMORY_INIT_FILE attribute to specify the .mem file which populates the memory during synthesis so you need to re-run Synthesis and PAR.
For more details on the INIT, method refers to the following UG: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug974-vivado-ultrascale-libraries.pdf#page=151
This issue will be fixed in the next release of Vivado, apologies for the inconvenience caused.
There is already a CR in place to address this issue, Hope this helps.
Thanks and Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
ansarimo
Thanks and Regards,
Ansari Hunen
