Visitor rendijs
Use commandline to generate .tcl from .xise
Hi,,
I'm using ISE Project Navigator 14.7.
Currently, the team is keeping the .xise project file in a git repository, and generating the .tcl file by performing "Project -> Generate TCL Script" in the UI of Project Navigator.
However, I am working on build automation, so need to be able to generate the TCL file from XISE from commandline. Is this at all possible?
Re: Use commandline to generate .tcl from .xise
Sorry, there is no ISE Tcl command equivalent to the Vivado write_project_tcl command.
There is not a Tcl, or other scripted way to run the "Generate Tcl Script" operation.  ISE was not Tcl based as Vivado is and therefore we had to build the Tcl environment/commands around the Project Navigator functionality rather than the other way around.
In ISE the generation of project tcl script (as with much of the ISE flow commands) worked on executing internal procedures that were wired directly with the GUI widgets.
Visitor rendijs
Ok, I'll stop trying to find a way to do it in the docs then, and try and come up with a different way to make this work. Thanks!
