Newbie driftdone
VHDL incomplete port maps
Hey guys,
In my design process I decided to create a generic component with 3 vector inputs and 3 vector outputs that can do the same operation in paralel.
My problem is that some times I only need 1 of those inputs/outputs and I am not very sure how to implement that.
Can I use the original component and map just the inputs/outputs that are of interest for me?
generic component
component generic_component
	port (
	 in_a : in std_logic_vector(32 downto 0);
	 out_a : out std_logic_vector(32 downto 0);
	 in_b : in std_logic_vector(32 downto 0);
	 out_b : out std_logic_vector(32 downto 0);
	 in_d : in std_logic_vector(32 downto 0);
	 out_d  : out std_logic_vector(32 downto 0);
end component;
 normal port map
	GENERIC_MAP: generic_component port map (
 in_a => sign1,
out_a =>sign2,
in_b =>sign3,
out_b =>sign4,
in_d =>sign5,
out_d  =>sign6);
wished port map
in_a => sign1,
out_a =>sign2);
Re: VHDL incomplete port maps
Yes you can do that with named port mapping. You can also use the keyword "open".
Teacher rcingham
Also, you may find it helpful to give default values to the input ports.
"If it don't work in simulation, it won't work on the board."
