VIVADO Packaging Custom IP : howto generate documentation and example links for the BSP
I have generated a custom AXI IP with the "create & package IP" tool of Vivado 2016.2.
I would like to add :
       - a high level driver for this IP
       - documentation and example code that will be available in the BSP (SDK)
Are any tutorial/documentation available for doing this ?
Kind regards,
Etienne
Re: VIVADO Packaging Custom IP : howto generate documentation and example links for the BSP
@etiennebieber,
Refer these links:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_2/ug1119-vivado-creating-packaging-ip-tutorial.pdf
http://www.xilinx.com/support/documentation-navigation/design-hubs/dh0009-vivado-using-ip-integrator-hub.html
Nupur
