sebo
Voyager
Voyager
VPSS - out of date IP
I use the Video Processing Subsystem in vivado 2018.3.
Something quite annoying is that the IP goes out of date at almost each 'out of context' run although I do not modify it's parameters. And, it does not get recompiled.
So I need to stop and re-run the implementation twice so it gets compiled and up to date.
It happens only with this IP.
What's wrong?
--Sebastien
florentw
Hi @sebo
I did some test with 2020.1 with the VPSS example design. I cannot really reproduce your behaviour.
The only behaviour I have is that if I change one IP in the design and do not hit validate, I never see the VPSS build out of date.
If I hit validate, the VPSS goes out of date but has the interconnects in the design (the VPSS includes an interconnect under the hood), so I do not think there is much to do here
Florent
florentw
Hi @sebo
This might be happening only with the VPSS because the VPSS might be the only HLS IP that you have in your design.
I would need to check if this is happening still in the latest version.
I would assume you can ignore the fact that this is marked as out of context. However this might be a time west because if anything else changes in the design you will have to recompile the VPSS
Florent
sebo
Voyager
Voyager
Hi @florentw
I might be wrong but the video frame buffer Read/Write IPs are also written in HLS. They do not happen to behave the same.
So far, we're stuck in an older version of vivado. I'll see later on if migrating to the latest version solve this.
Thanks anyway.
--Sebastien
florentw
Hi @sebo
Is the vivado project build under windows? If yes, this might be a path length issue if this is happening only to the vpss.
Also the VPSS has a higher level of complexity compared to other HLS based IP. This is a subsystem this means this is kind of a BD integrating multiples sub-IPs
Florent
sebo
Voyager
Voyager
no. built under linux red hat.
--Sebastien
florentw
Hi @sebo
Florent
sebo
Voyager
Voyager
Thanks @florentw.
I appreciate you tried to reproduce it. I don't understand either. Sometines, it goes out of date even if the changes are absolutely not related. The status changes when I launch the btifile generation (first step for vivado would be the generation of output product).
Anyway, I propose to close the subject.
BR,
S.
--Sebastien
